Darin T
  • in reply to: Function Lamona LAM4602 #471138
    Darin T
    Thanks Dave. I will have a look. Do you by chance know which relay is the grill. I will then be able to see if there is a short between them.
    Darin
    in reply to: Function Lamona LAM4602 #471136
    Darin T
    I will check the wires just in case. But in my mind i was thinking it might be the board.
    Darin
    in reply to: Function Lamona LAM4602 #471134
    Darin T
    Just tried it and doesn’t seem to be the case.
    Darin
    in reply to: Function Lamona LAM4602 #471132
    Darin T
    Thanks Dave. I will check it out. If they were shorted do you think the opposite would happen, if I turn the fan element on the grill would then heat up?
    Darin
    in reply to: Function Lamona LAM4602 #471130
    Darin T
    The fan element is not continually on. I think it is being controlled by the termostat. When the the function reaches requested temp the elements switch off simultaneously but then both come back on to maintain or increase temp.
    Darin
    in reply to: Function Lamona LAM4602 #471128
    Darin T
    It is controlled by a PCB.
    The fan works on all functions that call for it. Spins free if you spin it.
    Darin
    in reply to: Function Lamona LAM4602 #471126
    Darin T
    Electrofix, thought so. Any ideas what could cause this?
