David clogg
  • in reply to: Bosch Classicxx Wash Programme Not Completing. #356741
    David clogg
    Re: Bosch Classicxx Wash Programme Not Completing.
    sounds like not enough water in the machine, a common fault.The water level should be at the swage line at the front of the machine just below the door. To check there is an opening at the inside front of the plastic bowl where the filter goes, it kinda goes off to the left, this pipe can get blocked with gunge and effect the filling of the machine. the pipe goes to a chamber under the left hand side panel which also gets blocked with gunge. Simply clean and all should be well.
    in reply to: Hotpoint DWF30 problem #361921
    David clogg
    Re: Hotpoint DWF30 problem
    is the half load switch on if fitted. It can only be the bottom arms not spinning
    in reply to: creda oven grill problems #361798
    David clogg
    Re: creda oven grill problems
    Thanks for no replys guys.
    I have sorted the problem now on my own 😀
