David_355
ParticipantRe: Ariston A1635 W/Machine Error 3
Cheers,
I presume the water temp control is fine as on normal washes is fine and hot washes are very hot (little steam clouds come out of the detergent tray!)
looks like i need a call to a proper” engineer! as i would not like to tackle that job, i have had a look down where the programme knob and other assorted buttons are and it looks a real swine to fiddle about in down there! (didnt stop a spider making a home in the programme control knob though).The machine is 3-4 years old and actually is the landlords, would you think it is better to get it fixed or buy a new machine – he would spend up to £100 on a repair or he would buy a new one for £200 or so.
Personally i would have thought it better to buy a new machine (but then it is easier to spend more money when it is not your own!!)Anyone got any recommendations for good machines for a smaller budget? or any that you dont really want touch with a barge pole.
Many thanks for all your help so far (especially the link to approved engineers, takes the worry out of having someone in)David
David_355
Many thanks i will have a look tonight to see what i can find (other than spiders). Although the fault started before i moved the machine at all.
What does NTC stand for?
and any idea how much an NTC or control module would be?David
David_355
ooops, my bad 😳 …a1635!!
and it is the power light that flashes 3 times…pauses, flashes 3..etc etc.
Cheers
David -
