DHIRAJ S
  • in reply to: NEFF GAS Hob – Control Knob does not trigger Spark #468782
    DHIRAJ S
    electrofix wrote:it will be the switch that activates the spark generator gone faulty
    its a lot of work to fix ( hob has to be disconnected and stripped ), and it needs to be done by a gas qualified engineer, so go with this simple answer, its cheaper and safer
    Thanks Dave..
    in reply to: NEFF GAS Hob – Control Knob does not trigger Spark #468780
    DHIRAJ S
    kaibart wrote:Try pressing down one of the other control knobs so you get the spark clicking noise the turn the gas on to the one that’s not working and see if it will ignite
    Hi Kaibart,
    Thats an excellent advice and it worked like a breeze. The ignite from the other knob prompted the flame from the defective control knob..Thank you so much.
    Do you think its an issue with the Control know for the respective burner and does it need any replacement ?
    Thank you again..Much appreciated.
    in reply to: NEFF GAS Hob – Control Knob does not trigger Spark #468779
    DHIRAJ S
    Hi Kaibart,
