dr_skids
  • in reply to: Homark Oven User Manual #156003
    dr_skids
    Re: Homark Oven User Manual
    Thankyou for your polite reminder of the forum rules.
    I realise now that I may have breached them.
    So I followed the guidelines on checking the element.
    Unfortunately, even though homark make access easy from
    inside the oven box, there are special star shaped drivers
    for the element screws.
    I have requested UKWG repair help and hope they will be
    able to respond within the week.
    Dr. Skids
    Penguin45 wrote:Electrical test meter…….. I’ve told you what the forum rules allow. If you’re not sure how to proceed, you must get professional help.
    Check the repairs@ link below for a UKW engineer in your area.
    Forum rules are here:
    http://www.ukwhitegoods.co.uk/modules.p … pic&t=4361
    in reply to: Homark Oven User Manual #156000
    dr_skids
    Okay so now I am back. Can someone point me to a repair guide?
    Do these ovens have line fuses? What is the best approach to find
    the fault?
    Dr. Skids.
    dr_skids wrote:Hi every one,
    as per many other posters here I inherited the oven in the flat when I bought it.
    However, my problem is that the oven just stopped working – I guess it is
    just a fuse (maybe on the oven side as the hob igniters operate okay).
    05-703105A IX B11 is written inside right of door frame. Control layout is Left is a clock/timer with two spring-loaded “knobs”, Right pair of dials
    leftmost is the temperature setting, rightmost is the function setting.
    The oven light has never worked so I need a replacement for that too.
    I have no manual but the oven was fairly easy to work out and has worked fine for last 11 months. 😀
    Clues that it is broken 💡
    The clock would normally operate and make an awful noise but it has stopped. The control lights no longer work. There is no fan operation.
    Where should I look for a line fuse ?
    How does one access the innards of a built-in oven (dismantle it?).
    Cheers for any advice, will be away a few days but not using oven then,
    Dr. Skids 😀
    in reply to: Homark Oven User Manual #155998
    dr_skids
    Hi every one,
    Dr. Skids 😀
