el_ringo
  • in reply to: Candy CDI 45 – unable to select program #282490
    el_ringo
    Re: Candy CDI 45 – unable to select program
    It would appear the cause of the fault is a little steam escaping from the seal, condensing on the work surface and water dripping into the control module.
    in reply to: Candy CDI 45 – unable to select program #282489
    el_ringo
    I had to leave the flat for a several weeks so I drained it and left it open as you said. As we speak it is running!!
    Thanks again
    in reply to: Candy CDI 45 – unable to select program #282488
    el_ringo
    Thanks for the quick reply Penguin45.
    I have tried what you have suggested but the machine is still showing no signs of running a program. I will remove the PCB where the program button is and check it hasn’t worn out.
    Candy were unable to give me any advice over the phone and the cost of the call out is almost as much as another cheapo machine. It does feel like an awful waste having to bin it so soon.
    I would like to invest in a quality machine such as a Bosch but I plan to move within the year and would invest in the good one for the new place.
    R
