December 11, 2013 at 2:55 pm in reply to: Replacing Diplomat APM6855-1 integrated and in a muddle! #406093
frazzled fridgey
ParticipantRe: Replacing Diplomat APM6855-1 integrated and in a muddle!
although on closer inspection it looks like my existing fridge is on diy ‘legs’ about 8cm TALL. The cupboard doors themselves measure 99cm (fridge) and 94.5cm so the current fridge is raised to ensure it fits the doors I guess? The Goenja model diagram states that the bottom door needs to be 846mm …. help… is there anyway this can work for me?!!!
December 11, 2013 at 12:51 pm in reply to: Replacing Diplomat APM6855-1 integrated and in a muddle! #406092frazzled fridgey
Thank you so much, I can’t tell you how good it is to get some proper advice. I’ve had a look and am I right in thinking that because there is only a 54mm gap that the fact that it is 55mm taller than my existing fridge means that it’s 1mm to tall so the doors won’t match? (Also, is it frost free?)
December 11, 2013 at 12:04 pm in reply to: Replacing Diplomat APM6855-1 integrated and in a muddle! #406090frazzled fridgey
Oops, I meant currys! Thank you for your reply Don, my measurements are of the space as opposed to the existing fridge, is it the fridge I need to measure?
Are there any particular brands that are recommended? Or can anyone recommend a make/model for my dimensions? Regarding budget my parents have said that they can lend me a bit more money if it means getting a reliable fridge, currys charge £85 to install, im just wondering is that about right and can they be trusted!
Current fridge is 172cmx54cm
Also, am I restricted to a fridge of exactly the same height amd width or is it true that there is always a 5cm leeway in 50:50 fridges (I’m concerned about getting it wrong and the outer cupboard doors not fitting)
