G Carter
  • in reply to: Integrated Electrolux ESL6211LO leaking into tray #468083
    G Carter
    Just wanted to say thanks for your help with this Dave. Fitted the kit and the washer appears to be working as normal again. No water at all in the tray or elsewhere. The hot water is also back which is a bonus.
    Saved me a callout and having to wash dishes by hand for a while, god forbid
    Thanks again
    in reply to: Integrated Electrolux ESL6211LO leaking into tray #468081
    G Carter
    Yeah I directed the left overflow hose into a bowl to allow a wash without the water triggering the overflow sensor. The water is stone cold now.
    Ok, I’ll fit the kit when arrives and cross my fingers. Failing that I’m forking out for an engineer by the looks of it.
    Thanks again
    in reply to: Integrated Electrolux ESL6211LO leaking into tray #468079
    G Carter
    Hello again, just waiting for the kit to arrive but I’ve since ran the dishwasher a couple of times with the hose in a bowl catching about a litre of water and I’ve noticed it’s not washing with hot water. It’s running a completely cold wash.
    Could this be related to the above leaking issue or a separate problem entirely now?
    I’m sure it was warm water even with the leak before.
    Thanks again
    Glenn
    in reply to: Integrated Electrolux ESL6211LO leaking into tray #468078
    G Carter
    Brilliant, thanks.
    in reply to: Integrated Electrolux ESL6211LO leaking into tray #468076
    G Carter
    That’s great, I’ll give it a go. Does the kit include install instructions?
    in reply to: Integrated Electrolux ESL6211LO leaking into tray #468074
    G Carter
    Yep, mine definitely looks like the first pic… just the hole.
    Is this a mod I can do myself? No clue what I’d need.
    Thanks again for your help.
    in reply to: Integrated Electrolux ESL6211LO leaking into tray #468071
    G Carter
    Thanks Dave. Any idea why it would be suddenly overflowing and if there is a fix without me getting an engineer in?
    I take it the ‘tank’ is the space the filter sits in? This is full of water just now but looks normal. There’s no water sitting in the floor of the washer and all seals etc look fine. It’s only 5 years old.
    Thanks again.
