G-howes
  • in reply to: Miele F2 alarm #463733
    G-howes
    I think you might of been right with your first comment. I have used the sensor from the freezer evaporator which I removed and replaced with the new part and swapped it with the one in the fridge (which I didn’t know was there) and powered back up. As yet no F2 alarm.
    fingers crossed
    thanks for your assistance
    in reply to: Miele F2 alarm #463731
    G-howes
    Thanks for the reply.
    There was only one sensor on the evaporator at the base of the freezer. It was a Miele replacement which comes with a connector block. You done even have to remove the insulation just insert into the plug and push down.
