Hi Dave
Thanks for replying at the start of the program you can hear the pump start to empty the water from the previous program then you hear the water enter the machine . And stop when it’s about 20mm above the base of machine. The you hear may be a pump start trying to pump water around but nothing happens water coming out of spray tubes only low pressure and not spinning also detergent tablet is still in one piece. Plus water is cold not hot no matter what setting we use . Machine pumps out water ok ready for next program ok and bleep then finished.
Many thanks Gary
