Gazza.simpkins@gmail.com
ParticipantThanks again, will check it out.
ParticipantHello again. The dishwasher is now displaying F4 fault, after I open it and press the start button it completes the cycle.can I ignore it or do I have to pull the damn thing out again? Cheers
ParticipantThe motor now sound different though. Hope that’s not on its way out!
ParticipantHi Dave, the dishwasher is fixed! Took a bit of doing as the hose the split was in was integral to the motor, but after the use of a craft knife that was soon off. Many thanks for your help, the Mrs is very happy!
ParticipantThanks Dave, will pull it out next weekend. Can wash up by hand until then.
ParticipantJust looked on here and found a hose that fits the dwf 415. Would that fit mine?
ParticipantWhere can I get a replacement hose? Looked online but not found one. Thanks again.
ParticipantI have taken off the front cover and yes, it was full of water. Cleaned and restarted, it’s leaking. I can’t see exactly where it’s coming from but it’s spraying the back plate at the far right side. I think it may be the main motor at the back right, and maybe a pipe is loose or something. Without actually taking the whole unit out there’s no way to get to it as far as I can tell. Is this a common fault, ie a circlip just needs a tighten or something? Thanks
ParticipantHave taken a cursory look at the wires under the door and I can’t see any breaks in the wire. The start light is blinking twice then pause then blink twice etc.
ParticipantThanks Dave, I will check it out
