Gerry Sheldon
  • in reply to: bosch classixx 1200 express fail at rinse #429001
    Gerry Sheldon
    Re: bosch classixx 1200 express fail at rinse
    Gerry Sheldon wrote:This does not apply to the Rinse/Freshen Up setting, and I have just established that the Easycare programs appear to function correctly — it’s just the Cotton settings it would seem! So it would appear to be more complex than a blocked drain filter or even a bog standard programmer failure.
    Martin wrote:The motor brushes need replacing.
    in reply to: bosch classixx 1200 express fail at rinse #428999
    Gerry Sheldon
    An update: It appears to have stopped carrying out the wash motions at all — just takes on water, sits, drains, and then doesn’t start the rinse cycle and just sits with the rinse light blinking.
