grommit_lad
ParticipantRe: Bosch SGV57T03GB/02 dishwasher not filling
Are they inside the salt container and how do I access them and check them ….. what am 9 looking for? Thanks.
grommit_lad
electrofix wrote:check you have the wiring back on the metering unit microswitches. double check the pressure switch is in the empty position.
check wiring from Valve and microswitches to the timer in the door
open the timer and look for blown triacs
Hi Dave,
Have checked micro switches and correct placement of connectors, float is in empty position (there is no water in the chamber or the machine ….. sucked it all out.
I have had a look at the control pcb, no obvious visual signs of problems (nor sure which devices are the trials on the board).
Which valve are we talking about to check wiring? Not sure how the wiring runs from the inlet solenoid valve to the control board or if it goes via another component or connector. I will check wiring from micro switches etc tomorrow.
Thanks for your help.
grommit_lad
Hi Martin,
Not sure where the drain valve on the salt container is or what it looks like …. can you elaborate? Never put salt in the container as we have a water softener. I have sucked out all the water from the salt container hoping that would encourage filling…. the whole thing is now bone dry.
The plastic storage tank behind the left side panel was virtually full of water. When I removed it from the pressure chamber assembly a lot of water drained out (thankfully had an aquatic to suck it all up before it went everywhere).
Thanks for your reply.
grommit_lad
Hi Dave, I’m fairly sure it’s the main motor as I put a mark on the end of the motor shaft
