H-M3
ParticipantRe: Indesit iwme126
Thanks Dave. How the fart do I take the control module off? Tried taking the front turn knobs off but it feels like there is something else holding it. I also removed the 2 screws. Also what sort of cost approx for both pcb?
Thanks a millionH-M3
electrofix wrote:that’s fault 12
communication error between the 2 control boards
there is a control panel ( with the knobs on it) and a main board down at the back right. there I a cable (think its 4 wires) going from one board to the other. Find this cable ( at the top first for ease) unplug it and replace plug 2 or 3 times. If its a dirty contact then it will work again. if it does not work check the cable routing for any signs of cable damage
if all fails it could be a faulty board
🙁 did all that but still same issue. What’s the next best option? Can these boards be reconditioned or is it not worth it? Also how would I know which board is at fault?
Thanks again for your prompt responseH-M3
Checked seems ok the wires. Now when I switch it on it takes ages to light up!
H-M3
I can the cables. Will have to take back cover off to take the bottom one off. Shall I do the same for the door lock too?
Thanks in advanceH-M3
Sorry it’s lamp 1and 2.
H-M3
Thanks Dave it’s the 2 lights from the left.
Thans
