Helen Jones
ParticipantThank you Dave I tried that and all I get is this an error, loosing the will to live lol
Helen Jones
ParticipantOh I can’t upload the video, not so helpful is it 🙁
Helen Jones
ParticipantRe: Bosch WAE2416SUK smells of urine
Just an update to let you know i am still alive. After doing it the old fashioned way, one socket at a time, finally found the problem. The earth in the other socket had broken off meaning my kithcen sockets where not earthed, to much crammed in one socket, now been removed and have new wiring put in to kitchen sockets, now all safe
Again many thanks for all your help and a merry xmas to all 😀
Helen Jones
Things not looking good, brother still here trying to work out why there is a current on the outside of the sockets on that side of the kitchen, also the fisrt socket is live on the earth, not looking good
Helen Jones
oh but it was 😯
Just spoke to brother, who is not a sparky but very knowledgeable, well more than me. Anyway he is coming down after work to have a look and hopefully replace both for me and check other sockets 😳
Helen Jones
yes you did martin, i was fairly sure it was not a build up as the smell was so obviously not from something like that, will know more when i remove the socket hopefully, brother coming down tonight as feel a little apprehensive about touching the thing on my own, best blow him up rather than me lol
Can’t thank you all enough for all the help and support i have been given and probably the few hundred quid it has saved me, great board with some great members tooHelen Jones
Now stressed to the hilt, and near to tears, single mums eh, what has caused this? got to pull the other two appliances out yet that are on the same line or whatever it is called. Above the worktop is a socket type thing with a fuse in (no space for plugs, just a blank thing with a fuse in, from this is the fridge, then washer, then drier, is there to much on it? Grrrrrr
I have changed wall sockets and light switches before but that is about as far as i can go, but am concerned to what has caused this?
Helen Jones
all black stuff around prongs has melted too, knew this was gonna cost me more than a box of powder
Helen Jones
Well everything looks good under machine, but this not looking so good
Helen Jones
iadom is it the wires that clip onto the heating element?
like in this video http://www.youtube.com/watch?v=PMYM_j8Uoyk
I am having a problem distinguishing what a heater terminal is 😳
Helen Jones
thanks saabbafan, b ut this is why i did not think it was from build up as the washing does not smell at all, infact even immediately after opening door there is no smell whatsoever, only smell it whilst on and never after
iadom, will they look burnt out or something, will it be obvious there is something wrong, don’t want to be pulling it out till i definately know what i am looking for and how it should look, as i have never seen it before i need to know what it should be like, i am referring to the heating terminals not the plug or socket lol
Helen Jones
thank you iodom will pull machine out tomorrow you have any links to show what i am looking for inside the machine or will it be obvious
Helen Jones
Martin wrote:Burnt heater terminals or poor wall socket contact can give off a similar ‘whiff’…. 😉
How would i check this?
Helen Jones
Thank you kwatt. I do use ariel gel and will now purchase the powder and do a couple of boil washes with that and see if that helps, will also see if i can find some affresh, i have never heard of it or seen it so hold little hope of finding it but will certainly look, i have used gel for years with previous machine and never smelt anything like this and my last machine was years old. Thank you for the advice and link
