Helen S
Participantelectrofix wrote:what programme are you using ?
have you tried other programmes white cotton wash etc ?
It has all been reset (several times now!) so I can’t be 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure what I was originally using. Fairly sure I was on colour/ white but with temperature turned down to 40 so looking at it now that says 1.5 hours which sounds right. So that program broke (more than once) and on the screen it would stop and say 1:21 (though actually if I sat and watched it, it would go on longer than the 9 minutes down to 1:21, but then when I looked away and came back it would be stopped and say 1:21). Hope that makes sense not sure I’m explaining it well.
Once it breaks it takes a day or two before it will accept a reset. When it doesn’t want to reset it gives a little click sound, which is a bit like it’s tutting at me.
At that point the normal program was working fine so I used that quite happily for a couple
of weeks until that decided to break too. Now I’ve reset it again but I don’t trust it to work.Helen S
Participantelectrofix wrote:you need to work out what the machine is trying to do when it stops
does it stop full, empty, while its pumping? while its filling etc
Thank you for your response. It used to stop at 1:21? I don’t know how I would know what it’s trying to do? It’s definitely full of water because I always have to drain it to get my failed wash load out. But if it was draining and spinning and everything on one program fine but not on another, how can it be one specific thing? I thought it was maybe the ‘brain’ of it somehow? But I’m definitely no washing machine engineer.
Thank you for any help. -
