help needed
Viewing 1 post (of 1 total)
  • in reply to: Hygena AHY 8122 #235481
    help needed
    Re: Hygena AHY 8122
    I have the very same problem with my 8122!!!
    can you describe in a bit more detail which bit you fiddled with??
    I was guilty of not rinsing the plates sufficiently well- cauliflower cheese blocked the drain and water across the floor!!
    Attempted to clear the drain unsuccessfully, so baled water out by hand until i could see the filter and then clean it! machine is now constantly running the drain pump.
