I had the same problem on an almost identical model – water fill starts and stops repeatedly before draining and the red light flashing.
It was the reed switch on the side tank. Easy to fix but 30 quid for the Miele part.
I have seen the exact same fault on other machines of the same model series owned by customers and it is always the Reed switch at fault. Good luck.
