Is_it_time_to_replace
  • in reply to: Bosch WFP3300 Fault code F07 #335207
    Re: Bosch WFP3300 Fault code F07
    Thank you Beever!
    Beever wrote:F07 is the NTC o/c. also check the 2 brown wires all the way back to the PCB!
    All though the wiring/terminal blocks looked intact, one conducter had broken withinn the terminal block at the NTC end, repaired and happily washing away now 😛
    Thanks again
    in reply to: Bosch WFP3300 Fault code F07 #335204
    Can I take it from the lack of responses that I have a rare fault!
    Taking it further, is the part fitted to the rear of the hot water fill an electronic valve? or some crude temperature sensor?
    I’m guessing its a valve, regardless the fault occurs regardless of this being connected.
    Time for further testing
