J P
  • in reply to: Hotpoint CDN7000p has me beat #473882
    J P
    Hello, an update; The dryer worked fine for a day then the water light came back on, I popped up last night and opened up the float chamber – the rubber pump impeller was knackered and snapped. £5.99 replacement ordered. Thanks again for all your help
    in reply to: Hotpoint CDN7000p has me beat #473881
    J P
    Dave you were spot on thank you, float chamber now clean and light out, element on
    in reply to: Hotpoint CDN7000p has me beat #473879
    J P
    Removing the clear drain pipe the bottom tank looks empty
    in reply to: Hotpoint CDN7000p has me beat #473878
    J P
    Thanks Dave, I haven’t checked the bottom tank for water, looking at it now I’m wondering do I need to remove the complete back panel to gain access
    in reply to: Hotpoint CDN7000p has me beat #473876
    J P
    Brilliant help thanks, I have an intermittent float sensor illuminating the empty tank sign I take it this is what is shutting the element off
    do you have any advice on fixing the float sensor?
    in reply to: Hotpoint CDN7000p has me beat #473872
    J P
    Dave & Iadom thank you very much
    Iadom when you mention the stat located in the very top of the white plastic drum front support frame are you talking about the closed door switch? Does this also trigger the heater element? As mentioned the dryer runs as normal the only difference is zero heat
    in reply to: Hotpoint CDN7000p has me beat #473869
    J P
    Ind code
    95545674500
    serial
    503196315
    in reply to: Hotpoint CDN7000p has me beat #473867
    J P
    Hi Dave thank you for the reply
    The model number is CDN7000P(UK)
    You are spot on it has a mechanical timer, I did as you mentioned and ran it loaded on a long cycle cut no joy.
    There is no empty water light as far as I know, I will check the level tonight and top it up.
    Thanks once again
