j99_harris
ParticipantRe: Ariston AFA350x – Fails to start cycle
Jim,
Already had someone in – they said that it was the control module… 🙁
What does an aqua stop look like?
Thanks,
Johnj99_harris
Jim,
Changed out the module. This time the salt light (Red LED 2) flashes. The salt is full. Again it beeps 4 times when reset and selects the correct cycle according to the green LEDs. No water flows.
Is there a solenoid that controls water flow?
Wit the base of the machine off I can see the salt container is full (white crystals). The container next to it is a brown / red colour with what appears to be salt in it.
The drain appears to be clear, however any advise on where the drain is and what usually block would be good.
Thanks,
Johnj99_harris
Thanks Jim,
Can you source that?
John
j99_harris
Jim,
The 4 green lights do not flash.
However, they do change depending upon what cycle is selected. Only one green light is ever illuminated at a time.
It appears as though the selected cycle has started, however, no water pumps and nothing happens.
The base is not flooded.
Best,
Johnj99_harris
Jim,
Thanks, I’ll investigate.
Best,
Johnj99_harris
Jim,
All filters are clean.
The first red (ON) is the mains indicator, the second red is low salt (OFF) and the third looks like a sun (glass sparkle?) (ON)
The first green looks like a shower onto a plate.
I press “Reset” and the machine beeps 4 times. I then select a cycle and there is no further action.
Sounds like a s/w error. I just didn’t want to buy a board first to find it wasn’t the problem 🙂
Can I post a photo here?
Thanks,
Johnj99_harris
Jim,
From Left to Right
Red 1 and 3
Green 1John
