August 12, 2007 at 5:20 pm in reply to: Ikea DWF B10W Constant Bleeping and Flashing Start Light #212780
j_d0
ParticipantRe: Ikea DWF B10W Constant Bleeping and Flashing Start Light
Cheers for that, I have checked, all ok. After refitting motor, tried it, now flashing 7 times, any ideas for this fault code?
JohnAugust 8, 2007 at 6:32 pm in reply to: Ikea DWF B10W Constant Bleeping and Flashing Start Light #212777j_d0
I have rebuilt it and run it on a 40 cycle it did the forty mins and started beeping again
4 flashes, rinse cycle highlighted, undertray dry, I did give the black unit a thorough clean with a tooth brush and do not believe I broke the membrane.John
August 8, 2007 at 5:41 pm in reply to: Ikea DWF B10W Constant Bleeping and Flashing Start Light #212775j_d0
Thanks for the replys, I have cleaned the black unit, although looked clean, whilst I have the base off, the chamber next to the salt looks like dark soup!!! is this normal?
I still have to reassemble still to check.August 7, 2007 at 7:02 pm in reply to: Ikea DWF B10W Constant Bleeping and Flashing Start Light #212772j_d0
Hi DP, it flashes four times inside dry as a bone, and is not tripping the leccy.
JohnAugust 6, 2007 at 5:55 pm in reply to: Ikea DWF B10W Constant Bleeping and Flashing Start Light #212770j_d0
Hi mine has just started with the same problem, can you advise?
John -
