J_yo
  • in reply to: Help re Freezing Belling BIFF7030E #474984
    J_yo
    I hacked my fridge so you don’t have too, the fridge thermistor is located about 270mm from the top and 200 from right hand side as you look back at the fridge.
    I’ve cut my sensor off and is reading 5.72KOhm in a glass water and ice. Fair to say I need a new one
    in reply to: Help re Freezing Belling BIFF7030E #474983
    J_yo
    Have the same problem and wonder if anyone here managed to find the sensor location behind the insulation. I’m also after any tips that will help me to locate it. I’ve no problem digging the foam up as I can use expanding foam after to repair it 🙂
