James_Howard
  • in reply to: Still widl102uk water filling prob #249658
    James_Howard
    Re: Still widl102uk water filling prob
    washer is bosh and dryer is creda
    in reply to: Still widl102uk water filling prob #249656
    James_Howard
    I have fixed the problem!!
    I put it in the car drove to the nearest tip. took it out kicked it about 10 times then drove away laughing like a maniac.
    If you have a washer dryer then read the forums and that will tell u enough about what they are like.
    I now have a lovely washer and a separate dryer. And guess what? no problems 🙂
    Thanks for the help peeps. will be the last time i venture into the washer / dryer mix.
    James
    in reply to: Indesit widl102 #248970
    James_Howard
    Re: Indesit widl102
    its not connected under the sink or the u-bend of the sink. About 50cm down pipe it is connected. the pipe is about 3/4 up from the bottom of the washing machine. so i had to connect a pipe to that on a T junction which brought the hight above the machine.
    i dont get any overflow in the sink or anything like that.
    i also noticed the other day that if i leave it the water fills about 3cm in drum and then then the water switches off. this is same for all cycles even when drying.
