Jamie Woolgar
  • in reply to: Hotpoint WDPG9640 F15 error and won’t unlock #467890
    Jamie Woolgar
    Ran a dry cycle successfully, then ran another with some stuff in, it’s started failing again, and again it’s released water when it shouldn’t.
    I am going to ring Hotpoint tomorrow, thanks a lot for your help particularly as its Easter Sunday!
    in reply to: Hotpoint WDPG9640 F15 error and won’t unlock #467888
    Jamie Woolgar
    Ok thanks I will try that.
    I just ran a drain and spin cycle, it failed again half way through and was full of water, which is odd as I didn’t think a drain and spin would do that?
    in reply to: Hotpoint WDPG9640 F15 error and won’t unlock #467886
    Jamie Woolgar
    We don’t use the dryer very often, certainly haven’t for a few weeks. It’s just happened again half way through a cycle so will probably call an engineer out. Is it worth trying to clean the filters or something?
    in reply to: Hotpoint WDPG9640 F15 error and won’t unlock #467884
    Jamie Woolgar
    Thanks so much that worked a treat. Now I’ve got it open and the water out it seems to be working now.
    Any idea why it starting failing? As its happened once I assume it’s likely to happen again?
