Jo Hyaku
  • in reply to: BEKO 1530W dishwasher #467855
    Jo Hyaku
    Thanks for the confirmation. I’ve ordered the part you linked to and I’ll update when fitted. Hopefully that will be an end to the problems for now, and another skill learnt!
    Jonathan
    in reply to: BEKO 1530W dishwasher #467853
    Jo Hyaku
    Here we go again.
    The pump leak is fixed. I ran two cycles of fill and empty, and there was no leak at all. I completely drained the dishwasher last night and left it empty.
    This morning, there was a big puddle on the floor, and the bottom of the dishwasher (inside) is full of water.
    I force drained it (press and hold the start button) and the top two lights – wash and dry – were flashing together. I’ve tried to run a test cycle, but when I hold the start button and programme button all the lights come on, but they don’t go off afterwards. The cycle that did run was fine, hot water, no leaking, so I am happy about that.
    Once drained again I checked inside and noticed a constant dribble of water from the inlet on the left, so that must be how it is filling up. I can’t see where it is leaking out, but I assume there must be an overflow somewhere. Would replacing the inlet valve be the next step?
    Jonathan
    in reply to: BEKO 1530W dishwasher #467852
    Jo Hyaku
    Fabulous! An AC motor, then.
    Thank you very much for letting me know.
    in reply to: BEKO 1530W dishwasher #467850
    Jo Hyaku
    Update.
    Still haven’t got round to ordering the pump, but I have pulled the old one off and given it and the seal a good clean. I want to give this a final go, but I didn’t make a note of which wire goes where, assuming that it could only be connected one way round. I was wrong! The terminals and plugs are the same.
    I can’t find any images on the internet and I’m assuming it matters; please could someone tell me which wire goes where?
    Jonathan
    in reply to: BEKO 1530W dishwasher #467849
    Jo Hyaku
    Final message! I’m going to replace the pump. I read up about draining problems (ours has failed to drain a few times recently) and although it only seems to be leaking, perhaps a new one is the best way forwards.
    Now to wait for the “holiday” weekend before I can order, and hope that despite the collapse of world civilisation it will arrive before next weekend as we have to wash up by hand. We may be stuck at home, but there are many better things to do.
    Thanks for the help; it’s good to talk.
    Happy Easter.
    Jonathan
    in reply to: BEKO 1530W dishwasher #467848
    Jo Hyaku
    Dave,
    Already done that, minus the washing liquid, so I’ll have another go. It seems odd that a part like a seal is not separately available as it obviously has the potential to wear out. O rings are available in all sorts of sizes – I wonder if I can get one somewhere else. Talk about built-in obsolescence!
    Otherwise, unless I can find another way of sealing it, a new pump it’ll have to be.
    Thanks!
    Jonathan
    PS Just checked your link – there are two different pumps in the pictures. Mine looks like the second one.
    in reply to: BEKO 1530W dishwasher #467846
    Jo Hyaku
    The joint on the left. The drain pump is just off the edge of the photo.
    SKU 1740300300 – on this site, shop.ukwhitegoods.co.uk/1740300300-dishwasher-drain-pump
    On mine, the black ring is deterirating – black grime covering my hands!
    Getting there …
    in reply to: BEKO 1530W dishwasher #467844
    Jo Hyaku
    Yes, that’s it. I have cleaned everything out and refitted all tubes and reconnected the machine.
    But I now know that water is coming from the drain pump joint. It was damp when I refitted all the panels but I thought that this was because it had been disassembled for checking. A small amount of water appeared as it started to fill, but after holding the button to drain and stop the machine and the pump activated water started to come out in much larger quantities.
    Is it possible to get a new seal?
    Jonathan
    in reply to: BEKO 1530W dishwasher #467842
    Jo Hyaku
    Update.
    Part removed, a bit grotty inside, but not blocked (I don’t think). It’s got some numbers moulded on it – 175112 on one side and 175113 on the other; 19101 printed in black ink. Reassembling now!
    in reply to: BEKO 1530W dishwasher #467841
    Jo Hyaku
    Dave,
    I have taken a photo of the part I think is causing the link, but the upload failed with a message saying that it exceed’s the group’s upload quota. The photo is only 186.7KB, but it says that the maximum I can send is 19.5KB… I’ve resized it to the “smallest” resolution I can, but it’s still too big at 57.9KB!
    There is a pipe that leads from the sump up to a grey moulding on the right side of the machine. At the top end of this is a large hole that leads into the dishwasher, at the bottom end there is a smaller hole that is open. The pipe that leads to this part was blocked and I cleared it before running the machine again. It might be that there is a blockage inside the moulding, which I might have a go at removing and cleaning in case it is blocked too. The photo possibly makes it clearer.
    The sticker on the plastic cover gives a stock number 7669743842 and a serial number 10-104896-11.
    Thank you!
    Jonathan
