John Morris
  • John Morris
    Thats great Dave thank you. You input is really appreciated.
    Have a great weekend!
    John
    John Morris
    electrofix wrote:1 is the compressor running permanently ?
    2 if yes are the fans running in the freezer when the door is closed
    if yes to both then it sounds like a system fault which is faulty compressor or and gas leak
    Hey Dave,
    1 is the compressor running permanently ? No
    2 if yes are the fans running in the freezer when the door is closed? It doesn’t seem that fans are running at all…
    John Morris
    electrofix wrote:is it getting cold anywhere ie is the fridge at the correct temp of between 2 and 5 degrees or is it at room temp ?
    Hey Dave (and ADV)
    Many thanks for responding to my post.
    The situation was that the freezer section was not reaching the -18deg target. It was still cold, as was the fridge.
    I let the unit defrost for 36 hours and restarted it and borrowed a thermometer to check the temps. The freezer is running at 3 to 4 degrees and the fridge is at 9 degrees.
    Have you guys any idea what the cause of this might be please?
    Keep up the great work and thanks again.
    John
