Jon-g
  • in reply to: Beko DWD4310S thumping noise on fill cycle #438207
    Jon-g
    Re: [Solved] Beko DWD4310S thumping noise on fill cycle
    Happy to report that the new PCB appears to have done the trick both for the original issue (thumping noise on fill) and the secondary issue of boiling/overheating.
    Supplied with no hassle from the UK Whitegood Shop :tup: and fitted in all of about 5 minutes!
    Programme 1 (cold rinse) was cold and no thumping; I’m most of the way through Programme 3 (standard wash) with no thumping on fill and presumably no over heating!
    Thanks for reading – I hope this is of use to someone somewhere.
    Jon.
    in reply to: Beko DWD4310S thumping noise on fill cycle #438206
    Jon-g
    Re: Beko DWD4310S thumping noise on fill cycle
    Hi Simon,
    Thanks for that – I will do so. As it happened I did a programme 1 cycle this morning (cold rinse) and when it finished it was very hot and steamy inside so I would think that helps confirm your diagnosis!
    I’ll let you know the outcome in a couple of day hopefully.
    Jon.
    in reply to: Beko DWD4310S thumping noise on fill cycle #438204
    Jon-g
    Simon46 wrote:If your heater is staying on when it shouldn’t the pcb has failed.
    Regards Simon
    Thanks Simon… Any ideas if the two issues might be related? I.e. should I replace PCB and then see if it cures other issue (I am doubtful only because the former issue sounds mechanical).
    Thanks.
    Jon
