August 15, 2014 at 7:50 pm in reply to: Baumatic BT2710SS – All main oven functions not working? #417843
JPS Electrical
ParticipantRe: Baumatic BT2710SS – All main oven functions not working?
Martin, I really appreciate your confirmation, as I mentioned in my opening post I reluctantly agreed to take a look at the cooker only because this was a client who I continually do work for. I did inform them that this is work that I do not carry out and I advised they employ the expertise of a domestic appliance engineer but they really wanted me to see if I could help… Perhaps they have had previous dealings with engineers like Lee? Lol
Thanks again everyone, I hope you all enjoy your weekend 🙂
August 15, 2014 at 6:27 pm in reply to: Baumatic BT2710SS – All main oven functions not working? #417841JPS Electrical
lee8 wrote:It is a very obvious fault.
Have you taken the time to read this thread in it’s entirity?
I have frequented forums and moderated forums for many years and I quickly leaned that if someone didn’t have something constructive to add to a thread then they should just click next and see if they can help someone else.
I am a strong believer of “knowing your limitations”.
I don’t jump into something two footed especially when it has the potential to kill or at the very least seriously injure someone.
I am a Part P Approved Contractor. My area of expertise is electrical installations, it is NOT working with domestic appliances. If I thought I knew it all then I would not be here asking politely for assistance. I have not just asked “what is the problem”? I have tried to add some suggestions along the way, I have taken the time to add as much information as possible including a descriptive thread title to draw attention to future searchers who may have similar issues. I have also taken the time to post a number of photos that can be saved and posted by others IF they feel that would be helpful?
I don’t often bite, hence my last reply to your post BUT you do come across as being a complete prize plonker and I am actually starting to question whether you know the answer at all? :rotfl:
I hope you have a very lovely weekend and don’t feel the need to bless this thread with your presence again.
Much Love, Steve 😀 😀 :rotfl:
August 14, 2014 at 9:17 pm in reply to: Baumatic BT2710SS – All main oven functions not working? #417839JPS Electrical
Thank you for your constructive post Lee, it’s very much appreciated :rotfl:
August 14, 2014 at 2:47 pm in reply to: Baumatic BT2710SS – All main oven functions not working? #417837JPS Electrical
Last but not least.
Thanks in advance for reading 🙂
August 14, 2014 at 2:46 pm in reply to: Baumatic BT2710SS – All main oven functions not working? #417836JPS Electrical
Here is the photo showing the scorch mark on the side of the selector.
August 14, 2014 at 2:40 pm in reply to: Baumatic BT2710SS – All main oven functions not working? #417835JPS Electrical
Photos included
August 14, 2014 at 2:25 pm in reply to: Baumatic BT2710SS – All main oven functions not working? #417834JPS Electrical
Today I went back to my clients property and removed the top and rear of the cooker to see if I could perform a few more tests that would give a clearer indication of where the fault lies.
I took a number of photos with my camera this time and took additional notes. I think I have pin pointed the fault to be the selector unit which would make sense given the obvious scorch mark on the outer casing.
Firstly I tested for continuity between terminals 1 – 2 and 3 – 4 on the back of the timer (with cables removed) This was proven.
Then, with my continuity tester wedged in place on terminals 1 – 2 (continuity present) I rotated the timer dial clockwise, there was a click and loss of continuity just as the timed markings were reached. I continued to slowly rotate the dial and continuity returned. This was repeated for terminals 3 – 4 also and the results were the same.
On energising the appliance and carefully testing at the various elements etc I found Live present but no Neutral.
I isolated the appliance and traced all cables on the selector. Once confident I knew what cable was going where I removed the Neural connector positioned in port 11 of the selector and joined it with the Neutral connector in 11a.
I ensured that all the functions were set at 0 and energised the appliance again. I slowly worked selected each function and was happy to see that everything was working and heating up.
All I need now is to have it confirmed that this does prove the fault lies with the selector and that by replacing this the oven will be back to full working order?
I showed the client my findings and explained that I was putting everything back as it was until I had sought confirmation from an engineer.
I have included the various photos that I took today. Maybe someone else will find them useful in the future?
I look forward to any replies that may help me further.
Kind regards
Steve 🙂
August 13, 2014 at 9:51 pm in reply to: Baumatic BT2710SS – All main oven functions not working? #417833JPS Electrical
Jackal, thanks for your help.
The selector enclosure is white in colour and definitely has a very visible scorch mark on the outer casing.
As I mentioned in my opening post, I did explain to my client that this is not my area of expertise. If things need modifying then I will need to advise them to have an appliance engineer take over as I am sure my Insurances will not cover this type of work. Also, with the cost of the parts being so high I’m not prepared to start guessing and just replacing parts using trial and error.
Thanks again for the helpful posts 🙂
August 13, 2014 at 8:54 pm in reply to: Baumatic BT2710SS – All main oven functions not working? #417831JPS Electrical
Thanks for your reply Bryan 🙂
Where is the thermal cutout likely to be please?
As I mentioned, I have tested and confirmed that power is getting to the selector.
I’m wondering if I strip down the oven and bypass the selector and take power directly to each function I will be able to confirm a faulty selector? There is a scorch mark on the side of the selector housing (inside the oven)
I did try to post a picture but I am not sure how to make the photo smaller.
Kind regards
Steve.
