Justin Black
  • in reply to: Kettle fire tech question #434097
    Justin Black
    The first safety switch will activate if the kettle gets too hot, such as when the kettle doesn’t have enough water in it or the lid isn’t on properly. In these conditions, the normal thermostat control may not work and the water will eventually boil dry, leading to overheating and risk of fire. Be careful when picking up the handle as it’s likely to be hot, use a cloth or tea towel if necessary
    in reply to: Vacuum Cleaner Suggestion #299342
    Justin Black
    For efficient vacuuming of long hair, choose a model that comes with a hose made out of slippery plastic. It will allow for the free movement of vacuum strands of long hair, whether pet or human. A large diameter would also be essential to allow for easy inspection. The HOOVER Linx Cordless StickVacuum is an excellent choice for removing long hair. The cordlessvacuum design also touts a swappable battery design. This convenient feature means that if the battery runs out, you can replace it with another one.
