Larry May
  • in reply to: Samsung RL36SBMS Thermal Fuse #370614
    Larry May
    Re: Samsung RL36SBMS Thermal Fuse
    yes it did work, was a bit fiddly for me as I am a desk jockey now but with a little bit of perspiration and some perseverance the replacement of the heating part of the evaporator worked.
    in reply to: Samsung RL36SBMS Thermal Fuse #370611
    Larry May
    does the new heater fix to the evaporator with the same lugs or will I need some plastic ties. how can I order the part from you
    in reply to: Samsung RL36SBMS Thermal Fuse #370609
    Larry May
    Bryan,
    Just the new heater is removed and fitted? can that be done while it is still mounted in the freezer or do I need to pry it from the back of the wall?
    in reply to: Samsung RL36SBMS Thermal Fuse #370607
    Larry May
    Bryan,
    The buyspares item is incorrectly described then? the part you noted is the evaporator assembly.
    How easy is this to fit? it would appear that it is connected to the pipework at the back of the fridge will i need to cut or solder anything?
    in reply to: Samsung RL36SBMS Thermal Fuse #370604
    Larry May
    The part on buyspares is 5045-1721-4757-8
    Defrost Heater
    http://www.buyspares.co.uk/defrost-heat … y=rl36sbms.
    Sticks to the rear of the plastic cover to the left of the fan as you look at.
    in reply to: Samsung RL36SBMS Thermal Fuse #370602
    Larry May
    Thanks Bryan,
    The only things I disconnected were on the left hand side of the evaporator as you look at it.
    in reply to: Samsung RL36SBMS Thermal Fuse #370600
    Larry May
    Do I get to it by removing the panel in the freezer compartment? I have removed this panel to fit the defrost heater but cannot see it. is it at the top of the bottom, can I trace it from the plug at the top right of the freezer area?
