lee_yeovil
  • in reply to: WMA 33 #147795
    lee_yeovil
    Re: WMA 33
    Many thanks for your replys – will check them out.
    Iadom,
    I would be most grateful for a copy of the full service test programme, I’ll send you an email.
    Many thanks.
    in reply to: WMA 33 #147792
    lee_yeovil
    Re: WMA 33
    Thanks for the suggestions. I should have listed what I’ve so far checked in my original post, which is:
    Motor: Tacho Coil (continuity tested ok), brushes (no wear), insulation (fine)
    I’ve also visually checked for any chaffing of the wiring loom and all appears to be ok – will obviously check again.
    And because I’d got one handy, I’ve swapped the main board around, which gives the same fault!
    Unfortunately I don’t have an FHP motor in stock in order to swap/check it.
    Any more suggestions would be very welcome!
