Re: Hotpoint WDL520 Aquairous – washer Dryer fault
Thanks for your response but it doesn’t add up.
I can’t see how it’s a door lock problem as every thing else functions ok.
There are three drying settings on machine 11 cottons, 12 synthetics and 13 wool. I only get the problem when I dry on setting 11, it’s fine on the other two – could it be some kind of over temperature sensor kicking in somewhere?
Reading lights from bottom up it’s
F12 Washing machine display and control modules fail to communicate
Check electronic modules and connections.
So I should take pcb out and reseat everything? – is there a guide to do that anywhere?
thanks
