lucy_locks
  • in reply to: Fisher & Paykel smartdrive 708 and diagnostic trouble #252376
    lucy_locks
    Re: Fisher & Paykel smartdrive 708 and diagnostic troubl
    woohoo!
    It worked! I actually called fisher and paykel this morning in desperation and tech support said that I needed a technician to solve the problem-
    but obviously not!
    thankyou so much!
    in reply to: Fisher & Paykel smartdrive 708 and diagnostic trouble #252374
    lucy_locks
    well, I just spent the last half hour reading through the manual thoroughly, and came across the controlled cold section, so when you choose only cold, the progress light should be on ‘long wash’ but ours defaults about 2 or 3 LEDs across from that. The manual says press ADVANCE until it goes back to the coldest setting, but when I advance to spin (the last LED) it makes a lower sound as if it wont go any further (similar to if you click colder on the actual wash temperature when you are already on the coldest setting) so this makes me think that the issue is that the machine is defaulted on controlled cold, but we havent got a hot tap, only cold, so, do I need to fix the advance button?
