MaD_FOr_iT
  • in reply to: Help with a washer please #421247
    MaD_FOr_iT
    Re: Help with a washer please
    So would you recommend changing the element?
    in reply to: Help with a washer please #421245
    MaD_FOr_iT
    here is the error code i got
    Err 05
    The start/pause
    light and program
    end light blink.
    The heater of your
    machine or the
    heat sensor has
    failed.
    in reply to: Help with picking a new washer #278346
    MaD_FOr_iT
    Re: Help with picking a new washer
    thxx don
    in reply to: SERVIS 1300 DOES NOT SPIN PROPERLY #244914
    MaD_FOr_iT
    Re: SERVIS 1300 DOES NOT SPIN PROPERLY
    do u know if my presure switch is oki though going of my continuity test i didnt get any readings on so called default position ( only on plug 4-2but u dont use plug 4)but when i blow into it soft i get a readings on 2-3 but when i blow hard i get readings on all plugs 1-2 2-3 -1-3 ( it dose have 4 plugs but it only uses 3 wires)is this oki??
    in reply to: SERVIS 1300 DOES NOT SPIN PROPERLY #244913
    MaD_FOr_iT
    Washman wrote:Hi
    Have you checked the pressure switch tube , ie: when you removed the hose from pressure switch you blew down the tube.
    Posibly the pressure chamber on the sump hose underneath is blocked.
    Mike
    Switch off and pull plug out before checking.
    yer i checked the pipe blow down it ect seemed fine
