Madman_Greg
  • in reply to: CDA CW494 error code help #380516
    Madman_Greg
    Re: CDA CW494 error code help
    @kwatt
    – I have a multimeter so could check resistance across the heating element or temp sensor. What else could I check apart from continuity across the wires between components ?
    @chezza
    , will have a look at the wires and see what I can find.
    Thanks for the replies guys
    in reply to: CDA CW494 error code help #380513
    Madman_Greg
    I said I would report back on the test cycle
    It took close to 45 minutes and finished with 3 short bleeps, then one long bleep, no flashing lights.
    in reply to: CDA CW494 error code help #380512
    Madman_Greg
    I would also add, it does seem to take time to get up to temperature
    I will time the test cycle later. Which I understand should take around 15 minutes.
    in reply to: CDA CW494 error code help #380511
    Madman_Greg
    The water does get hot. I have not put a thermometer but it doies get hotter than the DHW which is around 50C.
    And there is steam from the drying cycle. Would need to investigate how the drying side of things work. Only looked at the water side of things so far.
    Thanks for taking time to reply.
