MARTIN HARRIS
  • in reply to: Bosch classixx 1200 express #242026
    MARTIN HARRIS
    Thanks for all the help gents,
    It was a blockage!! Not in my machine not in the machine drain pipe but just beyond the non-return valve as it enters the main waste pipe from the sink.
    The washer is now going like a good ‘un.
    Thank you all once again.
    in reply to: Bosch classixx 1200 express #242023
    MARTIN HARRIS
    Thank you gents,
    I will be looking into the waste pipe theory shortly I will let you know how it goes.
    Martin Harris.
    in reply to: Bosch classixx 1200 express #242019
    MARTIN HARRIS
    Hello gegsy,
    Thanks again for your time.
    It seems to be clear and yes it does “twang” as you describe.
    When the machine stops as in my original post I try and spin/drain, nothing happens at all until I drain the water out through the small tube at bottom. When most of the water is out then it will spin ok. I not sure what unusual sounds there are if any.
    I have just tried using the drain setting. Normal whirring sounds but it will not drain.
    martin harris.
    in reply to: Bosch classixx 1200 express #242017
    MARTIN HARRIS
    Hello gegsy,
    Thanks for your reply.
    I tried to spin out the washing on the spin cycle, it wouldn’t until I emptied the water out via the small tube at the bottom. I checked the drain hose, filter and impeller all seem clear as far as I am aware.
    I am not an engineer I don’t posses an electrical meter, sorry.
    Is the problem something to do with the “drain pump”?
    I will be calling an engineer tomorrow (Monday),any idea what I will have to pay?
    Many thanks once again.
    Martin Harris.
