Matt Nicoll
  • in reply to: Bosch WAE24162UK/01 Washing Machine Flash Codes #477265
    Matt Nicoll
    Thanks for your help, We done the reset procedure has we done before. With the delays etc, Not expecting it to work but low and behold the machine reset. (After doing the same procedure a numerous of times). Only difference this time was we forgot to shut the door.!!! Don’t know if this made the difference.
    But thanks to all.
    Matt
    in reply to: Bosch WAE24162UK/01 Washing Machine Flash Codes #477262
    Matt Nicoll
    Hi Bammec
    Thanks for the Reply but the Problem is we can’t do the reset code. Because as soon as you turn the programme knob to what ever position. The 3 led lights on the Set of five, Top, Middle and Bottom Light flash simultaneously. So the start button will not light up.
    Any Ideas Thanks?
    Matt
    in reply to: Bosch WAE24162UK/01 Washing Machine Flash Codes #477259
    Matt Nicoll
    Hi Dave Thanks for reply
    They were very worn and the commentator was very blackened which I have cleared up and seems to be working fine. This doesn’t seem to be the problem.
    Matt
    in reply to: Bosch WAE24162UK/01 Washing Machine Flash Codes #477257
    Matt Nicoll
    No I replaced the Brushes after the fault to eliminate the possible cause
    Matt
