Re: Hoover VH W654 D -Blowing drain triac
The wire from the pump is all ok no rubbing or breaks and it has continuity from end to end with no sign of a break and the triac does feed the pump.
I can feel the seal seems slightly damp to the touch (its not soaked and cant see any obviuos water marks but its not dry) where It connects to the drum so definatly will need resealing.
I think that could be the problem then small bit of water is shorting the pump. Will get some spades heatshrink and some adhesive to reseal the inlet.
