Mr Morden
  • in reply to: Zanussi thermaflow mode not working on oven #488964
    Mr Morden
    Thanks ill try taking cover off and see after the 1st jan.
    Your right i got numbers wrong, should be 948.
    And looking at icons on dial thermaflow has circle round fan where as fan mode has a line top and bottom.
    if i have cover off can also see if element at fan heats up when fan is on as well.
    in reply to: Zanussi thermaflow mode not working on oven #488962
    Mr Morden
    Is it an element if fan mode and grill modes are working ok?
    I can cook fine using fan mode and i use grill mode to preheat the oven.
    I looked at parts diagram for cooker and there are 3 elements one next to fan and 1 top and bottom.
    Does thermaflow mode when chose utilise a 4th element?
    edit..
    Checking meter i see
    grill mode :- 1.62 KW
    oven no fan :- 1.92 KW icon is —
    Thermaflow :- goes up by 2 watts (assuming thats fan doing that)
    grill mode with fan :- 1.62 KW
    Fan oven :- 1.95 KW
    bottom element of oven only :- 1.04 KW
    Defrost :- goes up by 2 watts, as no heat in this mode
    or is element at back of oven around fan only for thermaflow and not for fan mode?
    (With fan mode using top/bottom elements ?)
