January 17, 2023 at 10:32 pm in reply to: Zanussi ZOB 551x cooker fan won’t stop running after replacing grill #485413
mr_glide
Participantelectrofix wrote: change stat and it should be fine
https://shop.ukwhitegoods.co.uk/3570562011-oven-stirrup-thermostat-13062
should be this one
Thanks for the help, Dave! I will give that component a crack
Nick
January 17, 2023 at 2:29 pm in reply to: Zanussi ZOB 551x cooker fan won’t stop running after replacing grill #485411mr_glide
Participantelectrofix wrote:ok so you brok the stat
disconnect the other wire, insulate it
then turn on and see if fan runningif no its just the stat you have broken and you need a new one
Yeah, looks like it. I didn’t even get to the stage of removing the wire before it fell apart in my hands! Possibly may have weakened it when removing it to replace the previous element.
Anyhow, I removed the black wire, and the fan has stopped running. Something beyond a new thermostat, you think?
Cheers,
NickJanuary 17, 2023 at 1:11 am in reply to: Zanussi ZOB 551x cooker fan won’t stop running after replacing grill #485409mr_glide
Participantelectrofix wrote:ok from what i can see the wiring is ok
first thing to try
the thermostat to the right of element on the pics. Disconnect one wire and tape it up to stop shorting error
then turn on and see if fan runs and let me knowDave
Thanks again. Slight issue when I went to detach the thermostat wire, though. The light-coloured plastic part (https://imgur.com/Y03ejSR) had come free of the metal housing on its own, possible due the clips being bent outwards a little (https://imgur.com/arwQKOv). Also, I believe two objects dropped out of it, though I didn’t see them actually do so – a thin silver disc (a contact of some kind?) and something that looks a little like a transistor (https://imgur.com/7ZBPCyE). Any idea what I should do with those, if they are part of it?
January 16, 2023 at 10:20 pm in reply to: Zanussi ZOB 551x cooker fan won’t stop running after replacing grill #485407mr_glide
Participantelectrofix wrote: there will be a pnc number on the oven beginning 9497 let me have that
did you take a photo of the wires and not mix up the black and orange wires ?
Hi Dave, thanks for the reply.
The PNC is 949712893-04, and here’s a photo of the information plate in case anything else is useful: https://imgur.com/KazHS43
I believe I connected things back up ok – here’s the photo I took before removing the old element for comparison: https://imgur.com/XkamcZs . The only thing different is that the new element doesn’t have a middle terminal for the earth wire, but the crimp ring also on that same wire I left in place on the left hand bolt.
