mr_oj
  • in reply to: Replace Reed Switch Bosch Exxcel SMS50E12GB/16 #434958
    mr_oj
    Re: Replace Reed Switch Bosch Exxcel SMS50E12GB/16
    Thanks Martin and iadom.
    As you said, pull back the plastic flat and snap the new sensor into place. It wasn’t immediately obvious that the plastic surround on the new part was simply packaging to transport the sensor in. Once you pointed this out it was only a 5 minute job to replace it.
    Thanks again!
    in reply to: Replace Reed Switch Bosch Exxcel SMS50E12GB/16 #434954
    mr_oj
    Hi Iadom. The moulding of the chamber means that as far as I can see, the new reed switch must be inserted from the back. Additional images attached.
