Mr_Silverback
ParticipantRe: Its a mystery- Creda T622CW stopping
It works!
Just to let you know that the fault was actually a dodgy plug point. £80 of spares purchased and it wasn’t even the machine that was faulty!
Oh well- a lesson learned.Thanks for all your help and a great forum
😀Mr_Silverback
I’ve stripped down the door stuff now but still no joy. I get the feeling that the dryer is running hotter than it should do and that a thermostat is cutting it out.
Once the dryer has cooled own (about a minute) it will start again before again cutting out.(Thanks for all the suggestions so far)
Mr_Silverback
Guess what….. replaced the timer and its still cutting out after a minute or so! It seems to be heating up ok runs for a few minutes (on either gentle or high heat) and the stats, relay and timer have all been now been replaced. Any further suggestions very welcome!
PS anyone want to but a spare timer, relay, thermostats!Mr_Silverback
Thanks guys- tested the door stat and wiring and it seemed it certainly seemed ok. Guess I’d better order timer number 3!
February 7, 2007 at 7:37 pm in reply to: Creda T622CW No heat- and it’s not the thermostats! #200571Mr_Silverback
ParticipantRe: Creda T622CW No heat- and it’s not the termostats!
For anyone with a similiar experience- I replaced the timer unit (£30ish) and machine now works perfectly. Thanks for the help Jim, appreciate that your position re. detailed advice
January 25, 2007 at 10:59 pm in reply to: Creda T622CW No heat- and it’s not the thermostats! #200569Mr_Silverback
Thanks Jim. Had the timer out but I’m not quite sure what terminals/wire colours relate to the element circuits. Are you able to advise?
