mr_sneakster
ParticipantRe: bosch dishwasher
Thanks again guys for all your help, the problem was a 1″ tube which seams to fill up the d/w, well that was full of gunge so not allowing the fill process to complete, so I stripped it all down cleaned all the tubes and now it works 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} perfect, so ONCE again guys cheers, Steve.
mr_sneakster
Thanks guys for all your help and advise, I will check all avenues and let you know, I do know for definate the heater IS working, thanks again, Steve.
mr_sneakster
Hi Richard, thanks for that reply, the d/w is about three years old and is used sometimes 2 / 3 times a day every day, evertime is starts the cycle it makes a funny noise like water pipes banging, does that seam like the matrix blocked? cheers Steve.
mr_sneakster
Hi Martin thanks for the reply, sometimes it does not work on the other progs, so if it is intermitent, it could be all bunged up? we have never used salt to soften the water, only 3in1 tabs, whats the best method of de-bung so to speak? Steve.
