Re: Homark oven model 02-700401… not working.
Hi again 😀
Just a small note to thank you all for your advice regarding my oven problem, as a result of your sound advice my husband has pin pointed the problem to the timer switch.
Seeing that another timer switch is on order now and possibly take a few days to arrive, so would it be safe to use the oven without the timer switch connected?…… (Hubby has by-passed it with the use of a terminal block to connect the two wires together) and it works without any problems.
Could doing this have any safety issues?
Kind regards,
Karen
