neil_f
  • in reply to: Where to buy replacement brushes for Zanussi ZJ1218 #426779
    neil_f
    Re: Where to buy replacement brushes for Zanussi ZJ1218
    The carbon brushes are similar to Bosch parts and marked 39L 706. Have seen a few replacement Bosch parts marked 39L 010 and a few others with different last 3 digits. Does anyone know what these codes relate to?
    in reply to: Where to buy replacement brushes for Zanussi ZJ1218 #426777
    neil_f
    Have sent email with photos but unfortunately Dave doesn’t stock the brushes I need.
    The motor has no manufacturers label or recognisable marks of any kind. Very frustrating.
    in reply to: Changing main control board on Zanussi ZJ18 help with label #425009
    neil_f
    Re: Changing main control board on Zanussi ZJ18 help with l
    Have spent the whole evening taking various parts on and off the circuit board and attempting to translate German service manuals for similar machines but have successfully managed to make a repair. 😀
    There was a lot of fine soot around the power supply components, which took a lot of my time taking various components off and testing them but eventually it turned out to be nothing but soot. I think the transformer unit must run quite warm and the machine is 8 years old, so although it looked alarming it is probably to be expected.
    The real problem was damaged tracks on the PCB near the connector to the motor. The motor had badly worn brushes and (I’m told) had been making odd noises before it stopped altogether. There was evidence of arcing on one of the brushes in particular and the PCB track next to the brush connector had burned right through. The neighbouring track was also damaged but this was harder to spot because there was still enough track to buzz out the connection with a multimeter but too high an impedance to run the (newly refurbished) motor.
    All it took was a link across one track break and on the other I cut the connector off the cable and soldered the wire directly to a component leg on the board. I think the connector design is pretty poor given the power and type of motor. Was also surprised by how little information is available for these machines, particularly the PCB.
    I still need to tidy the cable harness up and put the back on the machine etc. but it has run a complete spin cycle and I have let it run 25 mins or so of a wash cycle and everything is working fine so very happy.
    in reply to: Changing main control board on Zanussi ZJ18 help with label #425007
    neil_f
    The price of a replacement board is around 50{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the price of a new machine which isn’t an economical repair in my mind. On the other hand it just seems wrong to scrap the machine when it is otherwise good. A £30 PCB from ebay seems like it may be worth a punt.
    Still keen to know if (similar) PCBs are interchangeable.
