nick dove
  • in reply to: Bosch WFK 6010; possible to replace brushes? #340239
    nick dove
    Re: Bosch WFK 6010; possible to replace brushes?
    Great. Thanks for this Twoten.
    I have already used this website to try to find a local engineer (though no luck yet) since I can’t do the tests myself. 2 visits plus part(s) with no guarantee pushes me towards a new machine, but I’ll see what I’m quoted.
    Many thanks once again
    Nick
    in reply to: Bosch WFK 6010; possible to replace brushes? #340237
    nick dove
    Dear iadom,
    Thanks for explaining about the photo upload. I couldn’t seem to make the photo appear despite using img before the link, but I have a least got a functioning link below, I hope.
    Dear Twoten,
    I fear you might be right about not being able to replace the brushes.
    I’ve taken the motor apart, but the rear motor casting looks a bit different to 496871, lacking the extra bit of metal in one corner that 496871 has:
    http://www.flickr.com/photos/31990220@N07/5337186314/
    vs
    http://www.worldofappliance.co.uk/carbo … 73f1b522ab
    In fact, my motor looks more like this:
    http://shop.ukwhitegoods.co.uk/Washing+ … Motor.html
    which is normally found in a range of different (but similar) machines.
    Or maybe the extra bit of metal doesn’t make any difference?
    Nick
    in reply to: Bosch WFK 6010; possible to replace brushes? #340234
    nick dove
    Well, I managed to get the motor out. It was a bit more complex than the videos but I won’t bore you as it looks like it’s a rare configuration (unless anyone else has a wfk6010 and would like to know).
    I can see where the brushes touch the coily thing but I’ve no idea how to get them out – it looks nothing like any of the videos (including the bosch one).
    I’d love to post some photos but have no idea how to do so. Any hints?
    Thanks.[/img]
    in reply to: Bosch WFK 6010; possible to replace brushes? #340233
    nick dove
    spanishwhite wrote:It is possible to replace the brushes,I have never done it on this machine but the brushes are listed as part no140865 on the bosch site.
    Muchas gracias para tu consejo.
    I will have a crack at getting the motor out. I guess worse case scenario is I order a new machine, which is probably what my wife prefers (though I’ve seen comments about the new machines being weaker due to plastic parts etc.).
    in reply to: Panasonic NNA755W microwave fault #300802
    nick dove
    Re: Panasonic NNA755W microwave fault
    Thanks very much Dave
    in reply to: Panasonic NNA755W microwave fault #300800
    nick dove
    electrofix wrote:both of these microwaves will probably say invertor on the front
    the electronics inside the machine switches the unit off if the microwave hass not started so your problem is in the invertor section of the machine
    this is not a home repair due to 5000 volts at the magnetron. it is likely to cost over £100 to put right but you may find a dealer with secondhand spares
    Dear Dave,
    Thank you very much for this.
    Yes it does have ‘inverter’ written on the front.
    When you write “not a home repair” do you mean that it would need to be taken to a workshop, or that it’s not a diy job?
    Thanks again
    Nick
    in reply to: Panasonic NNA755W microwave fault #300798
    nick dove
    I have an apparently identical fault on a panasonic NN A772S combination oven (microwave/convection/grill). I got/get the burning smell, the sudden failure, and switching itself off after precisely 10 seconds. Before switching off, at about 5 seconds there is a small click, and then more clicks around 7 seconds as though it’s attempting to do something.
    Convection still works.
    I am also looking to find out if I should pursue a repair or just buy a new one (it’s about 8 years old).
    Stephen – what did you end up doing?
    Nick
