Oliver Wylie
  • in reply to: SMEG SUK91MFX – Only heats/ grills if bang door hard #467270
    Oliver Wylie
    Hi, I’ve found the problem. I took off the back in the end and found something had burnt out. I can’t attach pictures due to the quota. It is a white box at the top right looking at the back, with most of the wires going into it. These then feed inside the cooker. The wires come from the mains to the circuit board and then into this white box. When I disconnected I noticed one of the pins has melted.
    in reply to: SMEG SUK91MFX – Only heats/ grills if bang door hard #467269
    Oliver Wylie
    Thanks- I can’t see anything when just opening the door. I’ll take it off & the panel to see if its behind there.
    in reply to: SMEG SUK91MFX – Only heats/ grills if bang door hard #467267
    Oliver Wylie
    [USER=”4209″]electrofix[/USER] Thank you. Where is the switch? I can’t see anything obvious. I replaced the hinges before, so wondering if it behind the panel there. Thanks
