Paul Russell
ParticipantThe dispenser release spring was broken.
Ok, all codes I have.
From the dishwasher label: S/N 410166993 36829131500
From the original dispenser label: W17400370403
35560004
41/14
From the control PCB: AZ183-01263-1 4391That’s everything I have.
Paul Russell
ParticipantAren’t the first and third link the same? Also, the second shows no info at all.
Latest update is that the dishwasher runs normally on a test quick wash, except for the detergent dispenser not working, and the level warning indicators showing as before.
The rinse aid sensor on both the old and new dispensers is identical (I pulled it out and checked all the circuit board markings). The actuator for the detergent dispenser is a simple two pin connection, and also identical to the old dispenser.
Unless the control PCB is itself faulty?
The exact model no is LTF8B019CUK.
Paul Russell
ParticipantIt was this part: https://www.ransomspares.co.uk/parts/dishwashers/whirlpool/inner-door-panel–tablet-detergent-dispenser-/825818.htm. It is indeed sold as one unit, but the door arrived damaged, so I just removed the dispenser and swapped out the broken one.
I’ll get the part number off the new dispenser when I next have access to the dishwasher. It’s at my son’s flat.
Paul Russell
ParticipantI disconnected from the dispenser (two plugs) and from the door close mechanism. The door sensor appears to be working, it’s just the indicators that aren’t. If I can’t verify the connections, I’ll try running the dishwasher and see what happens.
Paul Russell
Participantelectrofix wrote: i assume you have filled with rinse aid and salt
I have filled both.
