Peter Winstanley
  • in reply to: Beko CDA648FS/1 Frost Free Fridge Freezer-Fridge is Frozen. #409755
    Peter Winstanley
    Re: Beko CDA648FS/1 Frost Free Fridge Freezer-Fridge is Froz
    So i have found out that I need to replace the evaporator sensor on my Beko CDA648FS/1 Grey fridge freezer. The Fridge is freezing up on the back wall forming a perfect rectangle of ice/frost on the top half of the fridge back wall. I have located the evaporator sensor in the back wall but cutting away the insulation (10 inches acrogg – centre of the top and 10 inches down). Beko have said that the replacement part is 4394720185 but I am unsure how to fit it, please anyone who has successfully replaced this advise (Darrenw45?)
    Thanks,
    Peter Winstanley
    I too have the same problem,a rectangle of frost/ice is forming in the top of the fridge (about half way up to the top). The fridge is also freezing liquids and products. The compresor is running constantly which is probably why the fridge is so cold. HAs anyone managed to fix this problem successfully? If so please can you share what the problem was and how you fixed it?
    Thanks,
    Peter
